Activity Forums Adobe Premiere Pro Photo and After Effects Composition Duplicates
  • Photo and After Effects Composition Duplicates
    Posted by Travis Brown on April 30, 2012 at 4:05 pm
    So, I wonder if anyone has seen this before.
    I use CS5, and in one of my Premiere projects, whenever I import pictures into the project and put them onto the timeline, the individual pictures will be replaced with one (seemingly randomly chosen) picture – so all of the pictures on the timeline will be replaced by a single picture. If I go to the project panel, all the differently named pictures will show only that single picture when brought up in the source monitor. So, I can only effectively have one picture in my project.
    Also, a similar thing happens with After Effects compositions. This is more frustrating because I’ll replace a video clip in my timeline with an After Effects composition, then I’ll do another separate video clip saved under a different AE composition name but both compositions will end up showing the same video… Does this make sense? How is this possible?
    I’ve tried creating a new Premiere project and importing the old project into the new one. I also checked for updates.
    Any ideas?
    Ann Bens replied 14 years, 4 months ago 2 Members · 4 Replies
  • Ann Bens
    April 30, 2012 at 4:38 pm
    https://forums.adobe.com/message/3435962#3435962
    After you fixed the stills the AE problem might be solved also.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Travis Brown
    April 30, 2012 at 6:54 pm
    Thanks for the quick response.
    I’ll try that for the pictures, but I don’t know how that’ll affect my After Effects compositions. I tried recreating the compositions and that did no good. I also named them different things to no avail.
    I’ll give that “Save As” option a try in After Effects…
  • Travis Brown
    May 1, 2012 at 6:46 pm
    Replacing the pictures in Photoshop seems to have worked. I deleted all my After Effects Compositions and re-created them, and that solved that problem. I’m still not sure what caused the problem to begin with… but at least it’s all working now.
  • Ann Bens
    May 1, 2012 at 9:03 pm
    I’am guessing it was the stills, glad you got it working.
