Activity › Forums › Adobe After Effects › Phone Message Effect
  • Phone Message Effect
    Posted by James Tim on July 6, 2012 at 6:09 am
    Hi guys and girls,
    I have been looking for an effect where you have an actor using a phone and the text messages pop up on the screen while it is happening.
    An example of this is: https://www.youtube.com/watch?v=iXUxl0ciXyY
    Although I’d like to get it a little bit more defined and with the iPhone message style.
    I don’t know if I am missing a tutorial that is right in front of my eyes, but either way I require some help as to achieve this or a link to a tutorial.
    Thank you so much!
    James Tim replied 14 years, 2 months ago 2 Members · 2 Replies
  • John Cuevas
    July 6, 2012 at 11:35 am
    That is some text and graphics precomped, layered and moves into place with a couple of keyframes. Pretty simple animation, which leads me to believe you are probably quite new to AE. Take a look at this set of TUTORIALS from VideoCopilot. They will quickly run you through the basics of text, keyframing, transformations, everything you would need to make that effect.
    That being said, to create that, drag your footage on to the create new Comp button and in the projects panel rename it “Final”.
    Press “Cntl + N” to create a new comp and call it “Message 1”, use the text tool, shape layers, graphics…to design your phone message.
    Go to “Final” and move the Current Time Indicator(CTI) to where the first message should appear and drop “Message 1” into the comp. Press “S” to change the scale of the message. If you would like it to move a little like the first message does(In example video), press “P”, move the CTI to when the movement should finish and press the little stop watch icon(this sets your ending keyframe). Now press “I” to move to the beginning of your “Message 1” layer and either physically grab the layer and move it slightly, or use the X coordinates and slide them up or down to get the layer to move to it’s starting location. A new keyframe will automatically be generated.
    Press “0” on the number keypad and your frames will be cached to RAM(you will see a green progress bar) and when the RAM cache is full it will play back your animation. You can change the starting and ending points of your RAM preview by pressing “B” and “N”. Repeat these steps for all the messages.
    Finally I would suggest after you watch the tutorials, add some motion tracking to your messages so they move with the camera or the phone. Motion tracking is covered in those tutorials. Finally here is an excellent resource for Getting started with After Effects (CS4, CS5, CS5.5, & CS6)
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • James Tim
    July 7, 2012 at 2:05 am
    Hi there,
    Wow!
    Thank you so much for the links and the in-depth guide! You are a really good guy!
    James
