Activity › Forums › Boris FX Particle Illusion › Phaser Beam in Particle Illusion?
  • Phaser Beam in Particle Illusion?
    Posted by Tom Barratt on December 24, 2009 at 5:37 pm
    I am trying to create a space battle scene, which involves using ‘Lexpro’s Energy Weapons’ Library.
    However, the problem I’m facing is that I can’t get the beam to stop where it should (once it’s hit another ship). I tried using blockers to get it to stop where I want, but that’s time-consuming and the results aren’t always the best.
    I read somewhere that the Life of the emitter can be adjusted to allow it to stop where I wanted it to. However, I tried doing that, and the beam still carries on off the screen, it’s just shorter. Could someone please elaborate on this method, step-by-step, so I can get it to work?
    Or, if anyone has any other suggestions about how I can do this, that would be fantastic.
    Thanks in advance.
    Dietmar Jokisch replied 16 years, 9 months ago 2 Members · 1 Reply
  • Dietmar Jokisch
    December 28, 2009 at 9:58 am
    Maybe you could set the visibility to zero at hit time?
