Activity › Forums › Apple Final Cut Pro Legacy › Phase issue – Heeeeeelp!
  • Phase issue – Heeeeeelp!
    Posted by Toni Carey on November 9, 2007 at 10:45 pm
    Hi All,
    I’ve been tearing my hair out on this for a couple of days now and did go through all of the posts on Soundtrack and FCP but haven’t found the answer yet so I hope you don’t mind my posting but I could sure use some advice.
    I’m cutting a three-camera shoot in FCP Studio 2 where we had a professional sound person record two performers. One to the left channel, the other to the right. The sound person mentioned that I may have a phase issue because the performers were so close to each other and darned if I don’t and it’s driving me nuts! Singularly, each track sounds fantastic but together, they sound hollow and sort of echo-ish.
    I tried to send the tracks from my multiclip to Soundtrack as a multi track project. Once inside Soundtrack, I choose one track, click the analyze tab, check the phase box and click the analyze button. Once it’s done analyzing, it finds that one track is out of phase so I click on it and hit the fix button. So far so good right but here’s where I get stuck. How do I get the track back into FCP and replace the bad track with the good?
    I’ve tried saving it to the desktop but when I go back to FCP and try to import the new file, it won’t allow it to import. I get the “insufficient space” message.
    Again, I’m doing this as a multi track project. I could also just send a single track to Soundtrack, analyze it and save it but again, how do I get the darned thing back in?
    Thanks in advance for any help you gurus can provide!
    Best,
    Toni @ TONICK
    Toni @ TONICK
    http://www.tonickproductions.com
    2.16 GHz Intel Core Duo IMAC
    w/500GB Internal HD
    running MAC OS X 10.4.10
    (always updated to current version)
    2 LaCie 500 GB HD’s firewired to it
    Running FCP Studio 2
    Use Canon GL2 to shoot and digitize footage
    Toni Carey replied 18 years, 10 months ago 3 Members · 4 Replies
  • Colin Mcquillan
    November 10, 2007 at 12:47 am
    How about exporting an aif (48k 16bit) audio file from STP. Then import that aif file into FCP rather than the STP project file?
    Colin McQuillan
    Vancouver BC
  • Toni Carey
    November 10, 2007 at 12:59 am
    Thanks Colin, I’ll give it a try.
  • Michael Gissing
    November 10, 2007 at 1:08 am
    In sound post, this is very easy to fix and mix. Save yourself the agony and take the audio to a decent DAW/ mixer and they can mix between tracks as people are talking and fix phase issues by slipping tracks in sub frames.
    Whilst you are editing, I suggest delinking the stereo and just splitting and pulling down the other channel when that mic is not needed.
  • Toni Carey
    November 10, 2007 at 2:48 pm
    Thanks Michael and Colin. I was able to export the phase corrected file from soundtrack in an aif form and then import it back into FCP and replace the bad track. (after using Phase>invert in soundtrack pro).
    There were still some phasing issues though (so I’m not sure what the phase >invert actually did in Soundtrack) but I am alternately using key frames to pull the sound down when it bleeds into the non-speaking performer’s track and that is working really well!
    Can’t thank you guys enough!
    Best to you!
    Toni @ TONICK
