Activity › Forums › Audio › Phantom Power vs Battery Power Conflict
  • Phantom Power vs Battery Power Conflict
    Posted by Chris Dalrymple on April 14, 2008 at 11:46 pm
    I recorded some interviews with a battery powered wireless mic and accidentally left the 48v switch on my HDV camcorder on. Now those interviews I have captured to Final Cut has annoying pops. Interviews recorded after I had disabled phantom power do not. And I did not and still cannot hear those pops on the HDV tape played back in the camera. Any suggestions for a fix? Other than recording the analog output to a solid-state device, re-capturing and syncing everything double-system?
    Eddy Falconer replied 18 years, 5 months ago 5 Members · 6 Replies
  • Thaxter Clavemarlton
    April 15, 2008 at 12:30 am
    [Chris Dalrymple] “Other than recording the analog output to a solid-state device, re-capturing and syncing everything double-system?”
    That sounds like a good way to handle it.
  • Will Salley
    April 15, 2008 at 2:03 am
    Are you using a Sony Z1? If so, I’ve had the same issues when the phantom power is used with a cable with incorrect wiring (reversed hot). No problems with other cameras or correctly shielded and wired cables.
  • Chris Dalrymple
    April 15, 2008 at 2:16 am
    Bingo! I’ve got a V1U. And a cable courtesy of my mic vendor. Guess I’ll take it back.
  • Eddy Falconer
    April 18, 2008 at 6:10 pm
    hey, similar issue,
    can anyone tell me if leaving on the ‘battery on’ switch on a condenser mic while running the phantom power setting on the Marantz compact flash (the 660) will generate an ongoing annoying buzz on all recordings? or even just leaving a battery inside the mic?
  • Ty Ford
    April 18, 2008 at 11:07 pm
    Hello Reggie and welcome to the Cow Audio Forum,
    Leaving the battery in should be OK. Having Phantom on while using the battery can be a problem.
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
  • Eddy Falconer
    April 19, 2008 at 12:12 am
    Thanks, Ty, thought that might be the case.
