Activity Forums Apple Final Cut Pro Legacy Phantom Nested Sequence
  • Phantom Nested Sequence
    Posted by Alexander Lee on March 30, 2007 at 6:56 pm
    I’m cutting a multiple character documentary where I’ve made each character’s scene a nested sequence that I’ve placed into a master full assembly sequence. Before, whatever updates I’ve made within the individual nested sequences have been updated within the full assembly. But recently I noticed that edits that I made within the browser’s nested sequences were not being updated within the full assembly timeline. When I click on the nested sequence within the timeline, a 2nd tab of the same sequence will open in the timeline. This phantom sequence does not include the updates done within the browser’s sequence. I don’t have 2 versions of the same sequence in my browser, so I’m not sure if this is a final cut bug or not. Any info would be most appreciated!
    Alexander
    My specs:
    Macbook Pro 2.16 Core Duo
    FCP 5.1.4
    Steven Lambion replied 19 years, 5 months ago 3 Members · 2 Replies
  • Bob Flood
    March 30, 2007 at 8:30 pm
    Alexander
    Someone here once said that when you cut and paste your nests from one sequence to another, you lose the link and FCP treats the copy as a separate iteration ( I believe they call this a feature)
    HOWEVER
    nesting does not work! i tried creating a timeline, doing some work in it, then cutting it into another timeline. it stayed linked for a period of time, but then “myseriously” becam unlinked just like you described. for the life of me i cannot figure out how.
    SO
    i don’t do it that anymore. I always export a native quicktime of my sub-timeline and bring it back in. If i have to make changes, i avoid the “file in use” error when i try to overwrite by rendering it to the root of the media drive (aka the topmost level) and copy it over the old one in the media folder.
    its a pain, but at least I know which timeline i am working on. What i find scary is that FCP lets you make multiple copies of timelines, bins, or anything, all with the same name!
    hope this helps
    bee eph
  • Steven Lambion
    March 31, 2007 at 12:22 am
    I use nested sequence every now and again. I’ve realized that you should limit how much you use it. If your doing a huge project with many layers or a long timeline then it might work, other than that – no.
    It seems that nested sequences take up ram, processing power, and most of all… Render time!! They can also slow down finalcut and become really buggy when they take up memory.
    A few bugs:
    -After rendering the video will stay still will your trying to play it.
    -The sequence will unlink it self, like what happen to you.
    -while dragging the head over the sequence Final Cut Pro will slow down and sometimes stop for a few minutes to think(This is for every frame).
    -There are also export bugs that happen.
