Activity Forums DaVinci Resolve Phantom footage comes in magenta-ish
  • Phantom footage comes in magenta-ish
    Posted by Manuel Wenger on March 2, 2012 at 8:52 pm
    Prepping for a Phantom shoot which we will CC in our facility.
    Got a test file today and it shows up with a strong magenta hue, if i open the same file in speed grad on set, it looks as it should be.
    Is there a LUT especially for the Phantom somewhere or did i do something wrong ?
    thanks
    Manuel
    DP/ Colorist
    Munich-Germaany
    Manuel Wenger
    DOP / DIT / Digital Colorist
    Munich – Germany
    Manuel Wenger replied 14 years, 5 months ago 2 Members · 2 Replies
  • Sean Donnelly
    March 4, 2012 at 5:10 pm
    The problem you are seeing has to do with a somewhat recent change in the phantom .cine format. When you use the onboard flash memory of the camera the controller software now lets you download clips with a lossless compression (referred to as “packed”.cine files), which is now the default setting. I’ve seen this and similar problems with resolve and gluetools, as well as older versions of speedgrade. You can either transfer the clips out of the camera as unpacked, or you can use the phantom controller software to “unpack” them after the fact.
    -Sean Donnelly
    Digital Imaging Technician – ICG Local 600
    -Sean Donnelly
    Digital Supervisor, SFI
  • Manuel Wenger
    March 5, 2012 at 5:19 pm
    thanks for that information.
    best regards
    Manuel
    Manuel Wenger
    Munich – Germany
