Activity Forums DaVinci Resolve Phantom conform issues
  • Phantom conform issues
    Posted by Andrew Smith on February 26, 2013 at 11:27 pm
    I am trying to conform an xml that was made in fcp7 – the editor cut it in a 1080p29.97 sequence but the transcoded ProRes 1080 Phantom footage he was using was actually 23.98.
    Many of the shots have constant speed changes to add to the ‘fun’ BUT basically I opened up his fcp project and reconnected each of the shots to the 2k (2560×1600) ProRes444 Phantom ‘originals’ to actually grade with and of course using a reference quicktime from his sequence I matched by eye each shot because of course when reconnecting some of the shots slip/slide a few frames – this sequence I now have is 2k 29.97 and of course when i try sending that to Resolve everything is off by more than just a couple frames in resolve when comparing back to the offline reference.
    I want to know how best to approach this workflow – should i copy all the shots into a new 2k 23.98 sequence and move every shot to match the reference and THEN send it to Resolve? I am looking for the least amount of conform pain as i have to also match the framing he did in his sequence. I am meant to render out at 1080 but i believe the delivery is actually 29.97 so the editor or AE artist plan to take my renders and do that on there end.
    I know its a bit of a mess but I just walked in today and this edit has been going on for a couple weeks so it was out of my hands.
    Any help would be greatly appreciated.
    Thank you
    Andrew
    Andrew Smith replied 13 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
