Activity Forums Apple Final Cut Pro Legacy Phanther built RAID is slower w/Tiger than Tiger built RAID!
  • Phanther built RAID is slower w/Tiger than Tiger built RAID!
    Posted by Mitchji on July 22, 2005 at 7:20 pm
    Tiger built RAID is faster with Tiger BUT incompatible with Panther.
    https://www.amug.org/amug-web/html/amug/reviews/articles/tiger/drive.html
    Existing Apple RAID sets
    If you are using the Apple RAID function built into Disk Utility you will find that RAID sets built with Mac OS X 10.3 will work with Mac OS X 10.4. However, RAID sets built with Mac OS X 10.4 will not work with a Mac OS X 10.3 or earlier Mac OS system. Tiger RAID sets are seen as hard drives that need to be initialized on earler Mac OS X systems.
    In addition, my tests indicate using a RAID built with Panther on a Tiger system, reduced drive performance by as much as 10% when compared to using a RAID set created by the Tiger Disk Utility method instead. If you stay with Panther RAID sets for compatibility reasons while upgrading to Tiger there may be a small performance penalty.
    Since the purpose of a RAID in many cases is to increase hard drive performance you may want to be aware of this.
    Best Wishes,
    Mitch
    Mitchji replied 21 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
