Activity › Forums › Adobe Encore DVD › PGC “title of project” has an error at 00;00;00;00. internal software error: %0, line “title of project” – PGC Info: name=”title of project”,ref=Bpgc, time=00;00:00:00
Posted by Carla Silva on February 26, 2011 at 6:50 pmHello,
after 3 days looking for a answer for this problem…
Im posting this here for help someone with the same problem.My solution( after days, re-making my project, re-exporting in various formats without sucess):
1) In Premiere (I have CS5) project, in the timeline, take the Set Encore Chapter Marker and advance 1 frame after(in my project, before was in 00:00:00:00. Now, 00:00:00:01).
2) Then export normally, again.
Ready.
The Encore don´t show the error more…
I hope this help you…
Marcus Rosentrater replied 9 years, 10 months ago 9 Members · 9 Replies -
Bart Robbens
August 10, 2011 at 1:57 pmI’ve got the same warning now with a Main menu when I build my project…
So I can’t move anything in a timeline, because there isn’t any for a menu ofcourse. I’ve tried many times and now Encore build my project, but after I removed motion out of the menu.
So I can’t use motion in menus anymore? This can’t be true!
I build many projects/DVD’s in encore and I never had this warning before! Very strange…Any solutions? Can someone find the bug?
grts!
Lucas Barros
December 13, 2012 at 3:03 pmHey there guys,
this might be a little late, but I was having the same problem in an authoring I am doing here.
So, after days of searching and trying what worked for me was this:
deleting all the subtitles (I have 3 languages), changing their names to the simplest as possible (English.txt and so on…) and adding them again.
Worked perfectly.
I don’t know why it was happening or anything but I’m glad it worked as I was getting REALLY tired of
this problem. It’s only my second authoring in Encore, I used to be a diehard StudioPro user and although
Encore CS6 is way better I was just considering going back to the basics.I am running CS6 in a Retina Macbook Pro with Mountain Lion.
If anyone has problems like this and need a hand let me know, ok?
Lucas de Barros
http://www.novelofilmes.com.br -
Mark Cade
April 22, 2013 at 10:58 pmI’m at my wits end. I used dynamic link to open my PPro sequences in Media Encoder. Exported them from AME in the right format (that has always worked in the past for DVD’s. Then when I opened Encore and imported everything and programmed the DVD everything looked good. UNTIL I try and build it and when I try and build it I get this message.
PGC “1prep” has an error at 00;00;00;00.
internal software erroe: %0, line 1prep – PGC Info: name = 1prep, ref =
Dpgc, time = 00:00:00:00I’ve probably done about 30 DVD’s using this same method without a single problem. Also this doesn’t happen when I’m using Encore to author Blu-rays. I’ve read and read and read stuff online and have found nothing to fix this problem. I also went back and re exported the sequences using the same methodology (thinking that maybe something happened in the export)… same problem.
Any ideas anyone????
Fransisco Teo
October 28, 2013 at 5:43 pmI’ve run into the same problem, and it’s a subtitle problem. I have 2 solutions, the easy way n the hard way.
1). The hard way:
The error message pointed at a certain timecode, so go check on the subtitle on the corresponding timecode and there should be some block that sticks to next block. Just separate those blocks (even by 1 frame will fix it). The problem is if you have multiple errors like this, the next time u try to build the DVD it’ll show a similar error with a different timecode, so again u’ll have to go and separate the 2 subtitle block.2). The easy way:
I use SubtitleEdit, and when I check on my .txt file, it was on PAL while my DVD is NTSC. So all I had to do is change the subtitle format to Adobe Encore NTSC and re-import the new .txt.
Note: When u open a subtitle file with SubtitleEdit, it automatically displays what format it is. And any Adobe Encore format without the word “NTSC” on it is PAL -
Joshua Barnett
October 15, 2014 at 6:18 pmi am having this issue and customer support has been no help. i gave one dude AGAM, remote access. he fiddled around for awhile and then just shut down my computer hahha. anyways, what the hell is the issue here? while watching him work on my computer he seemed to think it had something to do with my audio files. I deleted them and tried and the same error came up. i do not have any subtitles in my project. its a wedding video. any help would be greatly appreciated. This is my first project with premiere and the adobe cc and im not off to a very good start.
Peter Gudmunson
July 9, 2015 at 10:03 pmI just wanted to log in to say thanks, Fransisco Teo.
After a couple hours of banging my head against the same error, I tried your method of adjusting the subtitles so that they didn’t touch around where the timecode was noted in the error. I had to do this a few times, but after they were all ironed out, no more errors!
Look at me, I’m excited about burning a DVD in 2015!
Robert Boni
February 9, 2016 at 3:25 pmNever seen this before after using Encore for 10 years until this morning. Using 5.5 on a PC. Read above tips and they did not rectify so tried sliding the entire video track in Encore’s timeline forward 7 frames or so. There was no audio in this project. It worked. Tried sliding chapter point (the one after the first point at 0:00:00:00) but that failed as well. Thanks for the posts.
Marcus Rosentrater
September 14, 2016 at 6:52 amI’m just here to post my solution for someone else’s benefit.
The problem I was having is described by Fransisco:
After getting frustrated spending 3-4 hours fixing each block and only getting about 30 minutes of an 80 min feature, I decided to fall back on my programming experience.
I wrote a script that would create a new subtitle .txt file, based off the original, but with altered timecode so that between each line of subtitle is 1 frame gap.
The code completed, new subtitle file imported, and in that nail biting build… finished without any errors.
I wrote the code in Ruby because I was most familiar with it. You’ll have to look up how to run the code, either inside of some coding software, or as an executable on your machine. I was able to cheat and run it in my text editor (TextMate). Mac or Linux users could turn it into an executable (adding “#!/usr/bin/env ruby” as the first line) and running it through Terminal. I have no idea how to do things on Windows. I’m sorry!
Link to code on github.
Here is the code:
new_file_path = "path/to/subtitle_fixed_file.txt"
File.truncate(new_file_path, 0)
new_file = File.open(new_file_path, "w")
file = File.open("path/to/subtitle_file.txt", "r").readlines.each do |line|reg = /;(\d{2}) \d{2};/
match = line.match(reg)if match.class == MatchData
m = match[1]
frame_number = m.to_i
if frame_number < 23
frame_number += 1
endnew_frame = frame_number.to_s.rjust(2, "0")
new_line = line.gsub(/(;)(#{m})(\s\d{2})/, "\\1#{new_frame}\\3")else
new_line = line
endnew_file.puts new_line
end
new_file.close
