Activity Forums Adobe After Effects PFHoe to AE wrong frame rate
  • PFHoe to AE wrong frame rate
    Posted by Jason Bullock on October 21, 2009 at 7:02 pm
    I just tracked a scene using PFHoe. It is at 23.98 fps. When I import the Maya file into AE, the frame rate changes to 30 fps. What is going on? Can anybody help?
    Jason Bullock replied 16 years, 11 months ago 2 Members · 3 Replies
  • Jason Bullock
    October 22, 2009 at 12:31 am
    The problem is not the footage. When I import the Maya file into After Effects, it creates a comp that is 30 fps. I was wondering is there a way to fix this problem.
  • Todd Kopriva
    October 22, 2009 at 11:47 am
    Changing frame rate for a footage item or a composition is described here.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Jason Bullock
    October 22, 2009 at 2:03 pm
    Tried that. The keyframes from the camera of the track do not line up with the original footage still.
