Activity Forums Adobe After Effects PF tracker export to after effects
  • PF tracker export to after effects
    Posted by Brandon Blomolux on March 25, 2013 at 8:05 pm
    PFtracker export for AE
    I am trying to export some track points from PFtracker to After Effects.
    Anytime I try to export a .ma file from PFtracker I get the following warning. Anyone know how to get around this???
    Walter Soyka replied 13 years, 6 months ago 4 Members · 5 Replies
  • Tom Daigon
    March 25, 2013 at 9:38 pm
    Does the frame rate of your footage or comp in AE match the footage that was tracked in PF Tracker?
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Brandon Blomolux
    March 25, 2013 at 10:41 pm
    Yes, everything is set to the same frame rate.
  • Jim Mcadory
    March 25, 2013 at 11:52 pm
    I don’t use PF tracker but I have written a lot of software and this message indicates that the variable “framerate” has not been initialized with a value within the application. This could be a bug in the application or it might indicate there is a preference related to the frame rate has not been set. I would start with double checking anyplace where you can select or type in a frame rate. If the selector(s) allow you to type in a value I would try that as I have see many cases where a drop-down type selector looks like it has the correct value but the program does not see that value until manually selected again or typed in.
  • Brandon Blomolux
    March 26, 2013 at 3:35 pm
    Hi, thanks for the reply. I have gone through and adjusted the frame rate in everywhere. But there may be some location that I am unaware of.
    I am not very familiar with the software either. For all I know I am just pushing the program to do something it is not supposed to do.
  • Walter Soyka
    March 26, 2013 at 6:53 pm
    I agree with Jim.
    Unless you feel like opening up that Python file and debugging it yourself, I suggest taking the error up with The Pixel Farm’s support. This is definitely a bug.
    Walter Soyka
