Activity Forums Adobe After Effects PF Track Image Distortion to After Effects
  • PF Track Image Distortion to After Effects
    Posted by Stephen Turcotte on December 16, 2013 at 3:19 pm
    PF Track allows for Lens Distortion Export as a .pfb file (PF Barrel file).
    Is there a way to input this or the data into AE? I have tried a few plugins and I can totally eye-ball it, but I’d much rather use the actual data from PF Track to assure that I’m applying the same distortion to the background plate.
    The reason why I don’t undistort in After Effects before tracking is because PF Track has a tool for this and tends to give more accurate results- giving the ability to refine and adjust as your solving the shot.
    Any input would be great!
    Pierre Jasmin replied 6 years, 8 months ago 4 Members · 8 Replies
  • 8 Replies
  • Oliver Zuniga
    July 26, 2016 at 9:06 pm
    Looking for an answer to this same thing.
  • Stephen Turcotte
    July 27, 2016 at 12:31 am
    I think the best solution is to export the plate right from PF Track. In the exports node, there should be an option fo you to export the image sequence.
  • Oliver Zuniga
    October 17, 2018 at 4:43 pm
    Still looking for an answer in 2018…. dammit..
  • Antony Dupsta
    January 8, 2020 at 2:37 am
    2020 still looking for an answer.
  • Pierre Jasmin
    January 9, 2020 at 3:55 am
    Some PF_Track users use our RE:Map UV — i.e. just use the UV map out of PF_Track as the metadata.
    Pierre
  • Antony Dupsta
    January 9, 2020 at 8:53 pm
    Thanks for your response.
    Yes we use RE:Map
    The only problem is that the edges get stretched with this plugin.
    For example: if you have an STMap that is 2048×1080
    You place this on your footage that is 2048×1080.
    40 pixels around the image is stretched when using this plug in. Pixel stretching.
  • Pierre Jasmin
    January 9, 2020 at 9:52 pm
    Those are values above 1.0 or below 0.0?
    Can you send me an STMap out of PF_Track
    There is a workaround but maybe we should built-in
    Pierre
  • Pierre Jasmin
    January 9, 2020 at 9:53 pm
    And that would be to techsupport at revisionfx dot com 🙂
