Activity › Forums › Panasonic Cameras › Petroff or Vocas Matte Box users help
Posted by Phil Yunker on May 18, 2009 at 8:12 pmHello,
I’m looking into buying a matte box and I believe I have narrowed my choices down to either a Vocas or Petroff for use with a HVX-200A and also being able to use the matte box with a Century Optics / Schneider Optics .75x w/a converter.I would like to hear the pro’s and con’s from current or past users of each matte box and if they are using a matte box with the .75x w/a
Thanks.
PHIL
Phil Yunker replied 17 years, 3 months ago 4 Members · 7 Replies -
Gary Adcock
May 18, 2009 at 11:05 pm[Phil Yunker] “I’m looking into buying a matte box and I believe I have narrowed my choices down to either a Vocas or Petroff for use with a HVX-200A and also being able to use the matte box with a Century Optics / Schneider Optics .75x w/a converter.
“I use a Vocas matte box (MB 250?) and have loved it from the moment I got my hands on it.
I use mine with french flags and eyebrow and I have the adaptor to use it on my EX also. I have found it as durable on my small cameras as my very expensive arri mattebox is for larger camera systems.gary adcock
Studio37
HD & Film Consultation
Post and Production WorkflowsCheck out
https://www.aja.com/kiprotour/Inside look at the IoHD
https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php -
Phil Yunker
May 19, 2009 at 1:51 amGary,
Thanks for the info.
Any experience using your Vocas with a wide angle adapter? pros / cons?thanks.
PHIL
John Fishback
May 19, 2009 at 2:52 pmWe have the Vocas and love it. We used it once with a wide angle adaptor (don’t remember which one) on our HPX500 and had no problems. That said, you might want to try the adaptor and matte box together before your shoot to be sure. That’s what we did.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Phil Yunker
May 19, 2009 at 3:15 pmJohn,
Thanks for the info. Can you expand on why you love the Vocas? Materials, ease of use, durability?any one else using a matte box with a wide angle lens adapter on a HVX-200A?
thanks.
PHIL
John Fishback
May 19, 2009 at 3:55 pmI’m not the DP so I’m reporting what I’ve heard. They particularly like the eyebrow flags. Durability-wise we’ve had no problems.
John
Jim Carswell
May 19, 2009 at 6:19 pmAs much as these posters believe in their Vocas matte boxes, I feel the same way about my Petroff. It’s durable, flexible and dependable. Everything is where it should be and operates as it should. The one negative is that when I put on my Century Optics .75 zoom through wide angle and have the lens on full wide I have to remove the matte box and use the Century Optics hood/filter holder in its place. If I’m not going full wide it’s not an issue. None the less, I still love the Petroff and would highly recommend it.
Jim
Jim Carswell
Spyhop Productions, Inc.
Savannah, GA
http://www.spyhopproductions.com -
Phil Yunker
May 19, 2009 at 6:24 pmJim,
Perfect. That’s the type of info I’m looking for especially about the .75 wide angle lens adapter.
Also, I did not know that there was a hood / filter holder for the century optics lens, thanks.
Thanks for the insight.PHIL
