Activity Forums Adobe Illustrator Perspective warp on an embedded image
  • Perspective warp on an embedded image
    Posted by Marty Hoedjes on October 17, 2010 at 10:37 am
    Dear forum,
    I have an embedded image in Illustrtor that I wish to warp according to its 3D perspective. The problem is that whenever I try to use a mesh, it creates handles so the edges start curving if I move the anchor points.(And bringing the handles toward the anchor points messes up the image.)
    I can’t directly select the anchor points individually neither, because it will cause it to select the entire image.
    What should I do?
    Greetings,
    Maarten
    Mike Gondek replied 15 years, 11 months ago 2 Members · 1 Reply
  • Mike Gondek
    October 19, 2010 at 3:20 am
    Have you tried Make with warp rather than make with mesh. You should have less problem uneven distortion.
    You can also use make with top object, but make sure your curves handles are created evenly using the classic 1/3rd rule of bezier curves.
