Activity › Forums › Maxon Cinema 4D › Perspective view
Perspective view
Posted by Lasse Ankanpää on June 7, 2009 at 9:33 pmHi
Is there a way to decrease perspective in perspective view? Cause when i zoom in closer to the object, the perspective is very big.
Brent Blaskievich replied 16 years, 1 month ago 3 Members · 5 Replies -
Adam Trachtenberg
June 8, 2009 at 1:52 pmIn perspective view you can move the camera in/out (physical) and zoom the camera in/out (focal length). Sounds like you’re zoomed out too far. Zoom in and pull the camera back.
Lasse Ankanpää
June 8, 2009 at 4:27 pmim not sure how to do that… (im a noob)
but heres what i meant:
so how to get the camera more like A and less like B -
Adam Trachtenberg
June 8, 2009 at 5:02 pmIf you are using the icons at the top-right of the viewport to navigate, left clicking and dragging on the second icon from the left moves the camera in and out. Right clicking and dragging zooms the camera in and out. So right click-drag on the icon to zoom in, and the left click-drag to move the camera back out. That will reduce perspective distortion.
If you want to eliminate perspective altogether, go to the viewport’s “cameras” menu and select “parallel”.
Brent Blaskievich
July 31, 2010 at 11:46 pmIf you add a camera and are looking through it (click square icon next to the camera on objects panel) you can change the amount of perspective in the cameras attributes. More flexible that just switching to parallel view.
