Activity Forums Adobe Premiere Pro perspective shadow
  • perspective shadow
    Posted by Tony Partam on February 8, 2006 at 10:18 pm
    Can we have a perspective shadow in premiere pro or is there a plugin that does it?
    All i want is to put shadow underneath a man on chroma key in a vitual background…
    Craig Howard replied 20 years, 7 months ago 3 Members · 4 Replies
  • Craig Howard
    February 8, 2006 at 10:30 pm
    You need to make a mask from the key. (Mask Only) . Place it on a separate layer and then apply a 3D Transform effect to it. (Might be easier in AE)
  • Tony Partam
    February 9, 2006 at 7:44 am
    wooww might be render time consuming…don’t you think?
    There’s a perspective shadow in AE but the same plugin is not working with premiere
    It’s strange Boris or any third party didn’t think of this plugin.
    I’m on a virtual program edit, everything is great on premiere except the shadow thing
  • Steve Slocomb
    February 9, 2006 at 4:19 pm
    Image Lounge plugin package does this easily in After Effects. The plug in is called “Real Shadows”. I use it all the time. Render time is not a problem. The problem is that the maker (Puffin) sold it to Pinnacle, who buried it. I don’t know if anyone else bought it. Scott Squires (ILM) was the creator and he has a blog…maybe knows where it can be found. BTW, the coincidence is we worked together on Star Trek in 1978.
  • Craig Howard
    February 9, 2006 at 7:06 pm
    I can not see any reason why the render time would be any longer than to be expected. (Plug-ins need to render also)
    Try it.
