Activity Forums Adobe After Effects Perspective Corner Pin without Position keyframes?
  • Perspective Corner Pin without Position keyframes?
    Posted by Wilhelm Hagberg on April 27, 2011 at 9:31 pm
    Hi
    I work with an interactive After Effect / Flash project. I have made a movie in AE with people holding billboards etc onto which interactive data is going to be projected with Flash.
    I have tracked my billboards with the Corner Pin Perspective tracker. Problem is, that when I apply the tracking to a solid (from which I will later export data to Flash) it aplies not only Corner Pin keyframes, but also Position keyframes. This doesn’t work for me, I need the solid’s position itself to be static, the illusion of movement and distortion only being “created” by the Corner pin effect itself.
    Any way to achieve that?
    Many thanks-
    Wilhelm
    Wilhelm Hagberg replied 15 years, 4 months ago 2 Members · 4 Replies
  • Tudor “ted” jelescu
    April 27, 2011 at 9:52 pm
    If you track with Mocha then you can export only Corner Pin data.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Wilhelm Hagberg
    April 27, 2011 at 9:57 pm
    thanks. I’m a bit hesitant to involve Mocha since I want to have a simple workflow (sometimes tracking has to be done in comps within comps etc) but if I find no other way I’ll try it.
    – W
    April 27, 2011 at 9:59 pm
    I believe you will find Mocha to be very easy to work with in any workflow – just track the clip you need, export data and paste to your layer in AE.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Wilhelm Hagberg
    April 28, 2011 at 2:15 pm
    Problem with Mocha, if i understand correctly, is that you have to use it with already rendered files. I want to track items in precomps. Any solutions not involving Mocha?
    thanks –
    Wilhelm
