Activity Forums Adobe After Effects Perspective Corner Pin Problems
  • Perspective Corner Pin Problems
    Posted by Stuart Samuels on April 30, 2016 at 7:51 am
    Hi.
    I’m attempting to composite Video Clip A (960 x 540) into a picture frame within Video Clip B (1920×1080).
    I want to use the Perspective Corner Pin in the Tracker options and it works fine when applied directly to clip A.
    However, clip A is shorter in duration than clip B and I want it to play until the end of clip B. So I duplicated clip A a couple of times so it repeats enough to fill the duration and then pre-composed the multiple copies of clip A into a single layer. When I apply the tracker info to the pre-comp the clip B is much smaller than it *should* be:
    Could anyone explain where I’m going wrong please?
    Thanks.
    Kalleheikki Kannisto replied 10 years, 4 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    April 30, 2016 at 3:55 pm
    You need to make the precomp 960 x 540. You’re applying the corner pin to a 1920 x 1080 precomp layer that has a smaller piece of footage on it.
  • Stuart Samuels
    April 30, 2016 at 4:03 pm
    Thank you. That worked perfectly.
