Activity Forums Adobe Premiere Pro Persistent crashing – and error message
  • Persistent crashing – and error message
    Posted by Max Frank on November 15, 2012 at 10:54 am
    I imported quite a complex project from FCP7 into Premiere Pro 6.0.2
    When I try export, I get this error message – and then it crashes:
    [/Volumes/BuildDisk/builds/slightlybuilt/shared/adobe/MediaCore/Backend/Make/Mac/../../Src/Sequence/TrackItemTrack.cpp-686]
    or
    [/Volumes/BuildDisk/builds/slightlybuilt/shared/adobe/MediaCore/MediaLayer/ImporterHost/Make/Mac/../../Src/Source/AudioSourceImpl.cpp-93
    Any thoughts what the problem is? Suggested fixes?
    How to locate the corrupted clips?
    Tx,
    Wayne
    Max Frank replied 13 years, 9 months ago 1 Member · 1 Reply
  • Max Frank
    November 21, 2012 at 3:00 pm
    I’m updating my post because this may help others.
    If you export a project out of FCP that has nests, Motion templates and the like, you are likely
    to see all of these fatal errors.
    I found that exporting using AUTOMATIC DUCK solved the problem completely!
    Thought I’d share the good news.
    Wayne
