Activity Forums Apple OS X Permissions are funny things
  • Permissions are funny things
    Posted by Naveen Mallikarjuna on June 22, 2010 at 3:58 pm
    So I’m trying to move a ton of files over from a PC to a new MacPro. Many of these files are Adobe After Effects files.
    When I try to open the After Effects files (which were created on a PC), the MacPro won’t open them. It says it can’t read them. I tried dropping the file name extension. Same result.
    I then copied a file and pasted it into a new location. OS X (Snow Leopard) tells me that
    “You may need to enter the name and password for an administrator on this computer to change the item named “XXXXX.aep”.
    When I hit “Continue” the admin login info window pops up, I enter the info, and then, wah la!, After Effects will open the file.
    I realized this is the permissions, so now if I go into the GetInfo for the file, I can change the permissions by adding myself and also changing “Everybody” to “Read & Write”.
    So the question now is, can I do this multiple files at once, or do I have to go into each file and reconfigure the permissions?
    Sacha Thomas replied 16 years, 3 months ago 4 Members · 4 Replies
