Activity › Forums › Apple Final Cut Pro Legacy › permanently setting default motion blur amount
Posted by Rick Dolishny on July 10, 2005 at 11:33 pmThe default amount is way too high for my work and I always change it – is there a way to set it to something else more-or-less permanently?
– R
Rick Dolishny replied 21 years, 2 months ago 4 Members · 7 Replies -
Walter Biscardi
July 10, 2005 at 11:37 pmJust set the blur amount you want and save it as a Favorite.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Rick Dolishny
July 10, 2005 at 11:42 pmSorry Walter I wasn’t clear … the motion blur in the Motion tab of a clip is currently set to a default 500 I need it preset to 90.
– R
Jeremy Garchow
July 11, 2005 at 12:06 amWalter’s right. It’s a bit of a trick though.
Put a slug in your timeline and give it the motion blur you want (90). Go to the modify menu and select the make favorite motion effect option (or hit option-f). You will notice in your favorites folder in the effects tab there will be a clip named Slug (motion). rename it Motion blur 90 or something like that. Double click the clip so it loads into the viewer. hit copy (apple-c). Select ALL of the clips in your timeline that you want to add the motion blur for and hit option-v (or select paste attributes from the edit menu). A dialog box will pop up, select the motion blur check box, & presto … motion blur on all of your selected clips.
Hope this is useful
Jeremy
G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
Walter Biscardi
July 11, 2005 at 12:10 amKeep in mind that Favorite Effects and Motions are kept in your FCP Preferences. So if you trash your prefs (which you’ll need to do from time to time when you crash) you’ll lose any favorite effects.
Create an “effects” project and simply drag any favorites you want to keep permanently into that project. I do this with Color Correction filters for instance.
Rick Dolishny
July 11, 2005 at 12:10 amVery interesting. Thank you for the detailed response and Walter for steering me in the right direction. 🙂
– R
Rick Dolishny
July 11, 2005 at 2:29 pm[David Roth Weiss] “Just like Discreet Edit 7.5 HD, right???”
David don’t confuse the poor apple cow folk! 😉
I will say this – notice the response times on my queries this week. Several solid answers in under 30 minutes. Reminds me of the “Good Old Days”. Nice to be in another active cow-munity!
– R
