perils of DVCProHD 720p30?
hello cow saviors-
i have a project coming-up that will be used primarily for sales presentations, web, VNRs, and possibly SD DVD… so, progressive output & interlaced output too. oh, and there’s also the “slight” possibility i’ll need to add SD video as well.
the camera is an HVX200 and normally i’d just shoot 720p/60 and not sweat it, but i’m also using a cinema lens adapter (buh-bye two stops!). if i jump from 60fps to 30fps i gain roughly one of those stops back which really helps the DOF issue.
the idea is to use the HD footage in 4:3 pan & scan in a SD ProRes timeline and deliver a 720×480(486) quicktime master file of a flavor to be determined (probably ProRes too, but…).
now that i believe i’ve given all the information, here’s the question:
is what i’m gaining on the front end by using 30p (getting greater DOF) something i’ll pay for after the shoot in the edit and/or delivery?
thank you in advance for your time, knowledge and patience.
e. eric johnson iii
eric@lillmonster.net
LILL MONSTER MOTION PICTURES
principal, producer-director-cameranow in post production – START 2 FINISH: What It Really Takes to Race A Bike
