Activity Forums VEGAS Pro Performance tweak for DVDA5?
  • Performance tweak for DVDA5?
    Posted by Nigel O’neill on June 12, 2009 at 2:51 pm
    Is there a performance tweak for DVDA5 to enable it to use more CPU threads like in Vegas 9 Pro? When rendering out to DVD on a Vista64 i7 processor system, CPU usage averages only 18% with only one CPU core bearing most of the workload. It is p-a-i-n-f-u-l-l-y s-l-o-w.
    RAM usage is 2.48GB with 9GBfree
    Nigel O’neill replied 17 years, 3 months ago 3 Members · 3 Replies
  • John Rofrano
    June 12, 2009 at 7:10 pm
    That’s why I render to MPEG2 in Vegas. I never let DVD Architect do the renders.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Martin Phillips
    June 12, 2009 at 8:50 pm
    I am having the same issue with V7 and my quad core – Joun can you assist ? Martin
  • Nigel O’neill
    June 13, 2009 at 6:00 am
    My workflow used to be Vegas Pro with m2t & AVCHD files rendered out to DVDA template (mainconcept mpeg2) as a single A/V stream. A one hour project from Vegas typically takes 2~2.5 hours to render as many tracks have effects and colour correction applied to them. I would then bring the files into DVDA and ‘make disc’. The ‘make disc process can take up to five hours! I noticed quality loss by this method, so I now render out from the timeline using the HDV 1440 x 1080i template and then bring that into DVDA. I don’t seem to get a ‘softening’ effect of the video like I was getting using the DVDA template in Vegas. Neither way seems to result in faster DVDA ‘make disc’. Is there an article on this forum outlining a workflow process from Vegas to DVDA?
