Activity Forums Adobe After Effects Expressions Performance of Shapelayers
  • Performance of Shapelayers
    Posted by Arne Münch on March 9, 2021 at 9:07 am
    Hello again.
    An interesting question I guess.
    If you set the expression of opacity of an whole layer to zero via expression, the layer doesnt seem to steal any CPU Power.
    The same thing doesn’t work for groups in shape layers. If you set that groups opacity to zero, the group still is calculated and steals performance.
    The only thing what helps is disabling that group, but this sadly is not addressable via expression.
    Is there a workaround or any idea about how to reduce the CPU performance of an shape layer group via expression?
    Arne Münch replied 5 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
