Activity Forums VEGAS Pro Performance
  • Performance
    Posted by Scott Francis on April 8, 2011 at 5:15 pm
    Hi All,
    Can anyone tell me why Vegas does not use a lot of RAM and processing power when editing? I have a hexacore system with 8 gig of ram, Windows 7 64 bit ultimate, Vegas Pro 10c and all my threads available and used in Vegas. When I watch my performance monitor under Windows it uses less than 20% cpu and just over 2 gig or ram….but the preview, x-fades and such have to be lower quality than I would like. What gives? Just with the system running with nothing open I use 3% cpu and just over 1.1 Gig ram….why does Vegas not use the resources available?
    Thanks for any help and insight!!
    Regards
    Scott
    Scott Francis
    Mind’s Eye Audio/Video Productions
    Scott Francis replied 15 years, 4 months ago 2 Members · 2 Replies
  • John Rofrano
    April 9, 2011 at 2:44 pm
    [Scott Francis] “When I watch my performance monitor under Windows it uses less than 20% cpu and just over 2 gig or ram….but the preview, x-fades and such have to be lower quality than I would like. What gives?”
    Only the Sony developers can explain how and why Vegas uses resources. I assume it doesn’t use more memory because it doesn’t need to. As for CPU utilization, I just dropped some test Panasonic HDC-TN700 1080-60p footage into a 720-24p project (just to give Vegas a lot of work to preview) and all 4 of my cores are blazing at about 75% the first time through.
    I will say that once watched, Vegas caches the frames based on my Dynamic RAM preview which I keep set to 1024MB because I use Boris BCC7 a lot, and the second time through the same clip, the CPU’s were only at 14%. So once Vegas starts caching frames it doesn’t use as much CPU. If you are never seeing the CPU’s up around 75% and the preview is stuttering, that is very strange.
    Other than that, how do you like your hexcore? I’m thinking of building one. What motherboard did you use?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Scott Francis
    April 9, 2011 at 3:40 pm
    I REALLY like my AMD 1090T BE!! I am using a GIGABYTE GA-890FXA-UD5 with 8 gig of ram and a 60 GB SSD drive for my system drive. I also have about 8TB of of drives from 1-2TB each. I also had a Blackmagic Intensity (PCIe) and capture BETA sp with that. All in all it has been really good. I had to adjust my sample size for my Presonus Firestudio so my audio was good when using a lot of Waves plugins…
    I was just really confused why I have to preview at “Preview Full” instead of “Best Full” when my resources are being used so little.
    This things COOKS when rendering….I remember when I was rendering with my Quad Core and on took 18 hrs, I did the same with this and it took 2.5hrs! Quite a jump….Vegas just baffles me sometimes though…
    Thanks for the input!
    Regards
    Scott
    Scott Francis
