Activity Forums Adobe Photoshop Perforated Metal/Grate
  • Perforated Metal/Grate
    Posted by Editbay1 on August 10, 2006 at 3:36 pm
    Is there any possibility someone would have a tutorial/solution on creating a perforated metal (coated in black) pattern as seen on the front of this speaker? I have been searching far and wide for tutorials across the web…all that is coming up is ‘perforated ball’ and I don’t believe that is right…and I have been using various keywords and phrases as well. You know, it’s the G5 enclosure perforated front panel look, but coated in black.
    https://www.yorkville.com/print.asp?type=29&cat=58&id=350
    Any input would help…
    Thank you.
    STEEL CANYON STUDIOS, LTD.
    Moving images | Moving brands
    Richard Harrington replied 20 years, 1 month ago 2 Members · 1 Reply
  • Richard Harrington
    August 10, 2006 at 3:41 pm
    I would recommend simply taking a photo or buying a stock one for $5 from istockphoto.
    Then use patternmaker or follow tuturial at phoshopforvideo.com on how to make seamless backgrounds.
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors, Understanding Adobe Photoshop, and ATS:iWork
