Activity Forums Adobe After Effects Perfect aligned masks
  • Perfect aligned masks
    Posted by Billy Rodgeers on October 29, 2018 at 1:57 am
    I want to break up a clip into multiple masks( for a kind of glass break effect), but I was curious if there is a way I can break them up so the edges align perfectly. With the pen tool there will still be some inconsistencies. Can I use some sort of alpha matte? Is there any way to snap them together? Thank you for any responses.
    Billy Rodgeers replied 7 years, 6 months ago 8 Members · 12 Replies
  • 12 Replies
  • Kalleheikki Kannisto
    October 29, 2018 at 1:10 pm
    Drawing them in Illustrator and pasting into AE is the easiest solution.
    Senior Graphic Designer
  • Billy Rodgeers
    October 29, 2018 at 2:56 pm
    I tried that, but there was an issue with pasting them in. It’ll paste the mask shapes in, but it always pastes them in the center of the comp, not in whatever position it was in the illustrator project. This isn’t too big of an issue, but it would be better if it could be solved.
  • Richard Garabedain
    October 29, 2018 at 3:41 pm
    is the iilustrator file size 1920×1080
  • Billy Rodgeers
    October 29, 2018 at 4:30 pm
    Yes
    October 30, 2018 at 4:58 pm
    Copy and paste them all at once to one layer, and they are aligned. If you need to separate them out to individual layers, you can copy and paste individual paths to new layers in AE. I suspect there’s a script in existence that splits them all in one go as well.
  • Hafeez Zainalabidin
    October 31, 2018 at 5:23 am
    Or if you have some coin to spare, you could get the Overlord plug-in from BattleAxe: https://www.battleaxe.co/overlord/
    I use it a lot because I work closely with illustrators and it’s been a dream to transfer their artwork into AE and have them fit just as intended in the frame.
    *full disclosure: this isn’t a sponsored post.
  • Billy Rodgeers
    October 31, 2018 at 5:26 am
    That certainly seems like a good investment. Thank you for informing me of it.
  • Michael Menefee
    November 1, 2018 at 3:03 pm
    Can’t you simply import the illustrator file as a comp and maintain layer size when doing so?
  • Ross Shain
    November 1, 2018 at 4:07 pm
    If you use the Mocha AE bundled with After Effects for masking, there is the “Attach Layers” tool that was made for this purpose. Each layer can have its own tracking and animation, than you can link the points at edges together.
    If you are using the new Mocha AE 2019, you find “Attach Layers” tool in “Classic” workspace.
    Ross Shain
    Boris FX / Imagineer Systems
    https://borisfx.com/products/mocha/
  • Mark Doctor
    November 1, 2018 at 11:07 pm
    Almost sounds like the old AE shatter effect. I suggest you check it out☺.
    Greets Mark
