Activity Forums Adobe After Effects per character ‘random’ animation (AE CS6)
  • per character ‘random’ animation (AE CS6)
    Posted by Dawud Ali on April 6, 2016 at 6:01 pm
    Hello,
    I’m wondering if Ae has something similar to random effectors of cinema4D or a way to achieve it, so to add slight individual (text) per-character rotations and position in XYZ. I’m aware of enabling per character 3D and using the animator/ range selector but this produces a uniformed results. Perhaps guys have scripts or written expression which enable this?
    Ideally a procedural method would be best where the text can be changed/updated as apposed to manually breaking the letters up and adding rotation.
    Thanks In advance,
    Dawud
    John Cuevas replied 10 years, 5 months ago 2 Members · 1 Reply
  • John Cuevas
    April 7, 2016 at 12:55 pm
    Under the Add pullout under selector, you need to add a “wiggly” selector and play with those settings, depending on exactly what you are trying to achieve. You could make it procedural by taking the rotation/wiggly and making them an animation preset.
    Here’s a little sample project. 9954_percharacterrotation.aep.zip
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
