Activity › Forums › Adobe After Effects Expressions › Pepsi Animation expressions?
  • Pepsi Animation expressions?
    Posted by Accountfrozen_needs_realname on January 4, 2007 at 11:40 pm
    I am not up to speed yet on expressions, however, a client has requested a treatment that looks like it could possibly be done in a more timely manner with expressions rather than animating with key frames. I could be way off base by this assumption but I thought it was worth a shot. The treatment comes from the pepsi website. One object in the center with other objects rotating around it in a 3D space. The only thing I would like to make slightly different is to make the objects blur as they go to the back of the circle and enlarge and come into focus as they come into the foreground. Any help is GREATLY appreciated. Here is the link to the pepsi site.
    https://www.pepsi.com/home.php
    All the best,
    skot
    Accountfrozen_needs_realname replied 19 years, 8 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 5, 2007 at 1:42 am
    I think you can do this pretty easily without expressions. Just arrange your 3D layers in a ring, add a 3D null at the center of the ring, and make it the parent of the other layers. Add a camera, enable the Camera’s depth of field, set the aperature pretty high (several hundred, maybe) and set the focus distance so the layers close to the camera are in focus. Select all your graphic layers and turn on Auto Orient (Layer > Transform > Auto-Orient > Orient Towards Camera). Now all you need to do is keyframe the Y Rotation of the null. I think that’s it.
    Dan
  • Accountfrozen_needs_realname
    January 5, 2007 at 3:43 am
    That worked great! I am on a tight deadline and you just saved me hours of work. Your website is very helpful and I often keep up with your posts and you always have great solutions. I am very glad you are so active on the cow and the ae user group posts. Thank you for all of your help Dan.
    Skot
