Activity › Forums › Adobe After Effects › Pen Tool Stroke offset and align to each other
  • Pen Tool Stroke offset and align to each other
    Posted by aaron smith on June 22, 2023 at 8:14 pm
    I used the pen tool to draw an s shaped line and duplicated the shape 1 in contents multiple times to offset them in the content transform controls. I’m trying to perfectly align 4 stroke lines along each other. It will align correctly in some spots but when the lines bend at the curve they lose their alignment to each other. I feel like what I need to do is create an expression and pick whip the content transform positions to each other. Has anyone done this before and know what that expression math would be?
    aaron smith replied 3 years, 3 months ago 2 Members · 2 Replies
  • Graham Quince
    June 24, 2023 at 12:59 pm
    Instead of duplicating, could you use a Repeater, I think that might solve the problem for you.
    If not, if you could post a screenshot of the whole of AE, it might be easier to spot the issue.
  • aaron smith
    June 30, 2023 at 4:53 pm
    Thanks for replying, I appreciate it. I tried the repeater initially too but it doesn’t work. The host spline path is very organic in shape and has many different direction of turns, which screws up the offset or repeater. I think what I have to do is instead of trying to make one large spline path, I need to make several shorter ones that just have only one turn/arch.
