Activity Forums Apple Final Cut Pro Pen tool shortcut for sound keyframes?
  • Pen tool shortcut for sound keyframes?
    Posted by Olly Lawer on April 19, 2012 at 12:49 pm
    I know you can manually set a keyframe in the Audio Panel but is there an option where you can set one by just clicking P as you can in FCP7?
    Also, I find it annoying how it sets a really tight fade out and I would like to adjust the value of this fade in music without having to put another audio keyframe in the middle and adjust that. Is there anyway to do this?
    Olly Lawer
    Grady Lawlor replied 13 years, 8 months ago 4 Members · 6 Replies
  • Jason Brown
    April 19, 2012 at 1:40 pm
    Not sure I understand ur second question, but the “shortcut” to creating audio key frames is to option click while hovering over the audio line. (same method as in fcp7)
    I haven’t found a keyboard shortcut for creating an audio keyframe.
  • Frank Valtellina
    April 19, 2012 at 5:38 pm
    Oh yes… you can add keyframes with keyboard shortcut!
    Select the audio level line than press Option+K.
    That’s all. 🙂
  • Jason Brown
    April 19, 2012 at 8:20 pm
    wow…thanks for this shortcut. I was dying trying to get this to work.
    It’s strange behavior…because you can’t just select the clip then use the keyboard shortcut, you have to actually click on the audio line.
    You should be able to just select the audio clip and press opt+K, then create keyframe. No good reason I see to have to click on the line, in fact if you aren’t paying attention…you might change the level on accident.
    -Jason
  • Frank Valtellina
    April 20, 2012 at 5:04 am
    I agree Jason… We should write this request to Apple.
  • Olly Lawer
    April 21, 2012 at 8:41 am
    Hmm, must be doing something wrong. Doesn’t work for me.
  • Grady Lawlor
    December 29, 2012 at 10:55 pm
    Thank you! I was also fighting this issue for a long time.
