Activity › Forums › Adobe Photoshop › Pen tool not smooth?
  • Pen tool not smooth?
    Posted by Shelby Medina on July 1, 2013 at 2:57 pm
    I’m trying to draw something using the pen tool in photoshop, but I have never actually used the pen tool that much before. The problem I’m having is that I’m making lines, but I feel like they’re very low quality, or jaggedy. Is there any way to fix this, or is this normal?
    James Alan replied 13 years, 2 months ago 4 Members · 4 Replies
  • Bill Stephan
    July 1, 2013 at 4:39 pm
    Shelby,
    Regardless of the fact that you are using the pen tool, Photoshop creates images using pixels, not vectors. That is why you see the antialiasing on the curves and diagonal lines.
    If you drew the same artwork in Illustrator, you would not see the problem. Illustrator creates artwork solely using points, lines and vectors, so there are no pixels to cause artifacts.
    You can lessen the issues you see in Photoshop by drawing in a larger or higher-resolution document. More pixels or more dpi will result in smoother curves and diagonals.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Shelby Medina
    July 1, 2013 at 5:05 pm
    Thank you very much for the response, great help!
  • Jonathan Ziegler
    July 2, 2013 at 8:25 pm
    Just to beat the point to death: I usually do any vector work in Illustrator. While I don’t mind using photoshop for simple vectors or selection vectors, beyond that it’s just not what the app was made for. Once you get some of the basics of Illustrator down, you won’t want to make your lines in Photoshop anymore. Incidentally, Photoshop really does a great anti-aliasing job when you import your illustrator files.
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
  • James Alan
    July 8, 2013 at 8:52 am
    In Photoshop, when you select a tool its settings appear at the top. Click on the pen tool as see the settings. Maybe it is very bold or something like that.
