Activity Forums Adobe Premiere Pro Pen Tool Mask – Straight Line
  • Pen Tool Mask – Straight Line
    Posted by Martin Gardiner on March 21, 2019 at 4:04 pm
    Is there a way to mask in Premiere a straight line using the pen tool? Would like the easiest way to draw a custom rectangle shape, I can use the 4pt polygon, but then I have to select the vertices and move them and try to keep all the lines straight. I can use the free draw bezier shape, but it doesn’t seem to allow you to lock a straight horz/vert line.
    Other than using the crop tool is there an easy way to do this in Premiere. Simple task in AE.
    Thanks.
    Martin Gardiner replied 7 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
