Activity › Forums › Adobe Illustrator › pen tool doubt
  • pen tool doubt
    Posted by Parthibaraj Rajasekar on January 10, 2017 at 8:12 am
    Pen tool doubt.
    I have a triangle path with points in all 3 joints of the triangle. Now I want to start another path from one of the points and extend to the center of the triangle. how do I start the new path from an already existing point? If I bring the pen tool to the point it changes into a – (delete point tool)… + (add point tool) works only on a path, not on point. but I want to start the new path from a point.
    hope my question is clear
    actually I want to draw a bit complex shape. but I have simplified it as a triangle.
    Vincent Rosati replied 9 years, 8 months ago 2 Members · 1 Reply
  • Vincent Rosati
    January 11, 2017 at 12:44 am
    Draw the new path with the pen tool, apart from the triangle. Then use the Direct Select tool to move the 2 new points into your desired position.
    You can’t actually add a second path from a point. It has to be a separate object.
    Vince
    *Please remember to Like an answer if it solves your question or gives you a good idea.
