Activity › Forums › Avid Media Composer › Pen tool
Pen tool
Posted by Greg Burke on July 8, 2011 at 11:04 pmHey Guys Im New to Avid coming from final cut, is there a pen tool to control the audio levels or anything like that in MC 5.5 Thanks.
I wear many hats.
http://www.gregburkepost.comHector Berrebi replied 15 years, 1 month ago 3 Members · 3 Replies -
Hector Berrebi
July 9, 2011 at 6:44 amhi Greg
yes, there is a tool in the smart tool pallet that controls audio keyframes on your tracks
you can map it to a keyboard shortcut… P for all it matters 🙂
then you have to activate it on your tracks. make sure RTAS is open then select “auto gain”
now with the general keyframe shortcut “ on your keyboard
you can place keyframes on selected tracks.it may seem a little clumsy at first when coming fro FCP, but you’ll get used to it.
avid editors switching to FCP often feel the same
get proper Avid training. it makes it a lot easier.
hector
Hector Berrebi
prePost Consulting -
Myles Richardson
July 9, 2011 at 10:10 amGreg,
You don’t need the RTAS open to use keyframes.
In the Timeline fast menu [bottom left of the timeline widow] select Audio Data and check the Glip Gain option.
With the Keyframe mode activated on the Timeline you can add a keyframe to any selected audio track by placing the position bar and using the keyframe button/ mapped keyboard command [it’s the pink triangle in the FX tab of the Command Pallette]
Personally I find this much faster than adding Keyframes in FCP as you don’t need to keep swapping tools.
To adjust the keyframe up or down simply move your pointer over it [it will change to the ‘hand’ symbol] and drag up or down.
To adjust left or right hold down the alt key whilst dragging.
To adjust more than one Keyframe at a time mark and in and out on the Timeline and all keyframes in between will move together (up and down, but sadly not side to side)
If you don’t want to see the clip gain info all the time save alternate Timeline views in the View Menu at the bottom of the Timeline.
You might also want to make the audio tracks larger to get more control over your keyframes – with your audio tracks selected press the Apple Key and ‘L’ to make the tracks larger (‘K’ to make them smaller). These views can also be be saved as custom Timeline views for quickly switching between cutting and key framing tasks.
Myles
Hector Berrebi
July 9, 2011 at 2:03 pm[Myles Richardson] “You don’t need the RTAS open to use keyframes.”
true
but it makes it easier to have it open for other reasons too (turning on and off waveform on selected tracks is a blessed addition and lacking in FCP)
and simpler to control on which tracks you want keyframes
the timeline fast menu is sometimes a bit messy, especially for new users
Hector Berrebi
prePost Consulting
