Activity › Forums › Apple Final Cut Pro Legacy › Pen Tool
Pen Tool
Posted by Martin Sterling on November 13, 2006 at 7:28 pmIs there anyway to have access to a pen tool simalar to After Effects of Illustrator to draw custom MAttes.
G5 Dual 2.0 GHz processor, OSX.3.9
Martin Sterling replied 19 years, 10 months ago 7 Members · 9 Replies -
Will Salley
November 13, 2006 at 7:32 pmIsn’t it the “P” key?
System Info – G5/Dual 2 – 10.4.8 – QT v7.1.3 – 8GB ram – Radeon 9800Pro – External SATA Raid – Decklink Extreme – Wacom 6×8
Rich Mcwilliams
November 13, 2006 at 7:39 pmi don’t know of a way to draw custom mattes in FCP i think the pen tool has different uses in FCP. setting keyframes and such
Tom Wolsky
November 13, 2006 at 7:39 pmYou mean in Final Cut Pro? There’s no such tool. There is in Motion.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Martin Sterling
November 13, 2006 at 8:00 pmHow about third party plug ins
Tom Wolsky
November 13, 2006 at 8:05 pmThe closest thing is a 64 point garbage matte filter, but not a separate pen tool. Plugins can’t add tools. Motion is your best bet.
All the best,
Tom
Walter Biscardi
November 13, 2006 at 8:16 pm[Martin Sterling] “Is there anyway to have access to a pen tool simalar to After Effects of Illustrator to draw custom MAttes.”
That is one glaring weakness in FCP and as others have noted, Motion is your best best for creating a custom Matte. You can send your shot directly to Motion for the matte, and then send it back to FCP.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Chad Denning
November 13, 2006 at 11:39 pmJust throwing out the obvious: while Motion does do that, Shake is a much more robust toolset for that type of job. The caveat being that the learning curve is steep if you haven’t used a node based workflow before.
Monkeys is funny
Chris Paul
November 13, 2006 at 11:42 pmThe Slihouette plugin does a marvelous job with this. It does both mattes & paint.
Chris Paul
POV -
Martin Sterling
November 14, 2006 at 8:05 amThanx, Where can I get the Silohette Plug In
