Activity Forums Apple Motion Pearl Necklace Animation
  • Pearl Necklace Animation
    Posted by Chris Stegner on January 30, 2008 at 11:37 pm
    Ok, I’m at a loss on this one. Help?
    I need to animate a necklace with a heart on it, swinging into the frame, swings for a second or two then breaks apart, the heart falls out of the frame and the necklace falls out.
    This will all be created with Illustrator parts (the heart, and the little “balls” on the necklace.
    I need to “attach” the little balls (actually little gradient circles) to the “path” of the necklace, so that they follow the path as it swings and moves about. Once it breaks (the path will actually be an open path so I can grab a point and “break” the path. As one end of the path falls out, the little balls stay “linked” with the path.
    In short, let’s say I have a perl necklace come in, swing (path moves around), breaks, both ends fall separately out of frame… all while the “pearls” stay attached to the path.
    WOW, I hope that makes sense.
    Any ideas?
    BTW, I’m also posting this to the After Effects and Flash Forums.
    Any help would be highly appreciated
    Zak Mussig replied 18 years, 7 months ago 5 Members · 4 Replies
  • Peter Wiggins
    January 31, 2008 at 12:07 am
    yes I think I’ve seen something similar.
    Peter
  • Chris Stegner
    January 31, 2008 at 12:54 am
    Thanks for the post Peter, but man that doesn’t help.
  • Arnie Schlissel
    January 31, 2008 at 6:33 pm
    Sounds more like something that should be done in a true 3D app, like Maya, Lightwave or Modo.
    Unless you want a really cartoony look?
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Zak Mussig
    February 6, 2008 at 9:10 pm
    I agree with Arnie that this probably won’t look “right” unless it’s done in a 3D app.
    If you’re looking to do it in Motion I would try a replicator. Make your “pearl” with a highlight toward one side and have each pearl on the “string” (your animated replicator shape) spina bit to simulate a changing perspective relative to the light source.
    I can’t think of any silver bullet for the heart, but I’d animate shapes and mask them with the heart object to try and simulate highlights.
    Hope that helps,
    Zak
