Activity Forums VEGAS Pro Peak vs. RMS and Audio Mix Settings
  • Peak vs. RMS and Audio Mix Settings
    Posted by Debbie King on October 23, 2014 at 3:30 pm
    Hi Everybody:
    I went to this website and came across this post. Would anyone know anything about this in regard to RMS vs Peak?
    https://www.gearslutz.com/board/9273285-post30.html
    Also, even though I am calibrating my speakers for theatre, which will be 79 to 82db, should I keep the mix console set to 0 to -6db?
    Thanks everybody! Any help you can provide would be greatly appreciated.
    Best,
    Debbie
    Debbie King replied 11 years, 11 months ago 2 Members · 6 Replies
  • Graham Bernard
    October 24, 2014 at 4:00 am
    [Debbie King] “Any help you can provide would be greatly appreciated.”
    Well, with regard to choosing between RMS and PEAK Metering, Debbie, and as you asked for “Any help”, you would be well advised to read this both straightforward and illustrative entree into understanding the feature-set of these two Tools.: https://support.biamp.com/Audia-Nexia/Miscellaneous/Peak_vs_RMS_Meters “Peak vs RMS Meters” paying particular attention to the final section: “Which meter should I use?
    Best regards
    Grazie
  • Debbie King
    October 24, 2014 at 7:51 pm
    Hi Grazie:
    Thank you so much for the article. Great help! When metering, do you keep your console between 0 to -6db? I was concerned about where the levels should be in Vegas directly while I calibrate my speakers.
    Many thanks,
    Debbie
  • Graham Bernard
    October 24, 2014 at 9:46 pm
    [Debbie King] ” When metering, do you keep your console between 0 to -6db?”
    After I’ve set my own tiny Studio Audio Monitors settings up, that Headroom would work for me. Sometimes, dependent on the job, I do move North towards -3dB.
    Debbie, I’ve got to ask, have you set your Audio Monitors up for your Editing Space? Here’s a useful Video Tutorial from Brent Heber. “Speaker calibration for Film and TV Sound Mixing“: https://vimeo.com/22735507 It’s chock-full of advice.
    Again, with regard to setting up your Monitors, I do recommend this thread on the SONY Forum: https://www.sonycreativesoftware.com/forums/ShowMessage.asp?ForumID=4&MessageID=884299
    I also had a Sound Pressure App on my iPhone! – Can’t find it now . . . .
    Grazie
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Debbie King
    October 24, 2014 at 11:23 pm
    Hi Grazie:
    Yes. I read the blog and saw the video a couple of days ago. It was very informative. I will watch it again. I remember him saying that if the room is small, between 79 to 80db should be the mark. I just calibrated my speakers today at 79db, because my room is small. I used the Presonus Studio One Tone Generator plugin, and the Radio Shack Sound Meter. If I go over 79-80db, my meter throws off the balance, and it seems that the meter is reading that one speaker is more sensitive. When I return to a lower db, everything synchronized.
    UPDATE: I just played some of the film in Vegas and the sound is much lower than what I calibrated. Could it be because I didn’t Pink Noise directly in Vegas?
    Thank you so much for your help Grazie. It’s very much appreciated.
    Best,
    Debbie
  • Graham Bernard
    October 25, 2014 at 3:12 am
    To determine that use what has been advised. Without following the advise I’d be only guessing.
    Grazie
  • Debbie King
    October 25, 2014 at 5:02 pm
    Hi Grazie:
    I found a download of Pink Noise and dropped it into my timeline in Vegas. It read the same as what was calibrated by Studio One’s Tone Generator. I’ll share the link, just in case someone reads this with the same problem. https://duc.avid.com/showthread.php?t=87830
    Thank you so much for your help.
    All the best,
    Debbie
