Activity Forums Sony Cameras PDW-U1 will not format
  • PDW-U1 will not format
    Posted by Brian Young on March 8, 2013 at 10:48 pm
    Greetings All,
    My U1 works fine for burning material from the nanoFlash to 23 or 50gb discs, but i get an error code (0xA100001A) when attempting to format a disc via xdcam drive utility.
    Thoughts?
    It’s not really pressing, as everything seems to be good, but I’m more curious than anything….
    Best,
    Brian
    Brian Young
    Los Angeles
    http://www.FlacaProductions.com
    Brian Young replied 13 years, 6 months ago 2 Members · 2 Replies
  • Ian Cook
    March 11, 2013 at 1:15 pm
    what version? make sure you are running the correct driver version and that there are no pending firmware updates (check this in the Utility after verifying/installing any updates)
    https://www.sonycreativesoftware.com/xdcamdrive
  • Brian Young
    March 11, 2013 at 5:44 pm
    Apologies Ian and thanks for your help. I thought I was up to date on drivers/firmware, but an update to firmware 2.54 and driver 4.0.1 did the trick – thank you!
    Brian Young
    Los Angeles
