Activity › Forums › Media 100 › PDW-F70 XDCAM HD disc direct to standard def DVD?
  • PDW-F70 XDCAM HD disc direct to standard def DVD?
    Posted by Thomas Hughes on February 23, 2007 at 1:51 am
    We shoot XDCAM HD, then edit on Final Cut. We master/archive to the PDW-F70 deck through an AJA Kona box.
    Is there a way to make a standard def DVD from the PDW-F70? I want the picture to be 16X9 with letterboxing on the top and bottom. I don’t want to stretch the picture nor cut anything off.
    What’s the cheapest way to do this? Is there a box like a small AJA box that I could use between the PDW-F70 and the standalone DVD burner?
    Thank you.
    Michael Slowe replied 19 years, 7 months ago 2 Members · 1 Reply
  • Michael Slowe
    February 23, 2007 at 11:54 am
    Doesn’t the deck you mention have a downscale facility? When I master HD to the HDW-F500 I can then take off a DVCAM copy using the decks’s very good downscaler. I then can then make SD DVD’s in the normal way. Alternatavely I downscale within my editing system (Media 100, also a good downscaler). Finally, another way is to use BitVice for your DVD’s and that also contains a downscale option which I often use.
