Activity Forums Sony Cameras PDW-F70 software bug
  • PDW-F70 software bug
    Posted by Mark Maness on July 2, 2007 at 5:54 pm
    I think I may have found a bug in the machine software. At least, if its not, then it needs to be addressed.
    I have my program that I write to disc HD and I would love to make an SD copy of the program at the same time WITH timecode. My thought was to connect my PDW-1500 to the SDI output of the F70 along with timecode. Well, when I look on my 1500 deck, I get anamorphic video, not the letterboxed output that is setup in the F70 menus. If I had more cabling I would run straight out of my Kona 3 as SDI to my 1500 deck, BUT I don’t have any extra cables for this. Then I could use the F70 for timecode output.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
    Mark Maness replied 19 years, 2 months ago 2 Members · 2 Replies
  • Andy Mees
    July 7, 2007 at 5:05 pm
    hey Wayne, I’ll check that for you but, baring emergencies, I’m not in the office for a few days. will let you know. Andy
  • Mark Maness
    July 9, 2007 at 12:32 pm
    Thanks, Andy, I would really appreciate it.
    It may not be a bug BUT if its not, it should be a menu selection on the SD output. Knowing Sony, its not a bug or an issue they had considered.
    Wayne Carey
    Schazam Productions
