Activity Forums Sony Cameras PDW-800 vs PMW-500
  • PDW-800 vs PMW-500
    Posted by Bill Paris on November 13, 2010 at 6:07 pm
    Looking into purchasing the new Sony PMW-500, but after getting close to pulling trigger also considering buying the F800/F700 instead. I’ve been shooting with the PMW-350 now for about 6 months and have been happy with the camera and the work flow, but would like to upgrade to the better sensors… higher bit rate and the XDCAM codec.
    Any thoughts would be appreciated.
    Thanks in advance.
    Bill Paris
    Producer/Director of Photography
    Crew Hawaii Television
    http://www.crewhawaii.com
    Pablo Balsa replied 14 years, 3 months ago 8 Members · 12 Replies
  • 12 Replies
  • John Sharaf
    November 14, 2010 at 3:05 pm
    As a PDW700 & F800 user/owner. I have really fallen in love with the XDCAM disc media. It is so cheap, reusable and the ability to hand it off is so convenient. Furthermore cheap file based recorders like the Nanoflash and Ki Pro/Ki Pro Mini can leverage even better recording formats when necessary. In addition the inexpensive PDW-U1 reader is a “no brainer” to help clients integrate the media into their workflow.
    JMHO,
    JS
  • Bill Paris
    November 14, 2010 at 5:35 pm
    John,
    Thanks for your response, I was hoping you would share your thoughts. Have you found yourself transferring files to drives for clients that don’t have the XDCAM players? Do you use the PDW-U1 to accomplish this or the Nanoflash? I’ve found many of my clients are comfortable with the XDCAM EX codec since many of them have used footage from the EX-1/EX-3, but I could see providing them with Pro Res via the Nano flash could also work. What has your experience been?
    Bill Paris
  • John Sharaf
    November 14, 2010 at 6:14 pm
    Hi Bill,
    What I do with clients new to the XDCAM Disc media, is loan them the PDW-U1 Reader until they are comfortable with using it, then I either sell them one or rent it too them at $100/week.
    For my own projects, I prefer to use my PDW-HD1500 Deck and play into FCP through the Kona card as ProRes. This eliminates a lot of rendering of the project on the way out of the machine.
    I’ve also used Nanoflash to record higher bit rates for commercials and other more “EFP” type productions as well as recording on to the discs for backup. I have to say that I’ve just sold my Nanoflashes in anticipation of delivery of Ki Pro Minis which offer 10 bit recording taking the “upmarket” even further, while at the same time offering “Direct To Edit” (DTE) workflow as established by the Alexa, meaning that you can edit directly from the media (in this case CF cards) without even importing. This obviously has advantages when you’re in a super-hurry.
    The PMW-500 while recording onto SxS cards still doesn’t offer this workflow as the media is still XDCAM codec vs. ProRes, which is immediately editable by FCP. I see this as a disadvantage mainly because of the cost of the SxS cards (although the 64Gb does lower the per Gb cost by half) without actually taking advantage of the write speed of which they are capable (like the Alexa does).
    JS
  • Don Greening
    November 14, 2010 at 9:04 pm
    To put the compression differences between the XDCAM EX and the Arri Alexa cameras into perspective, it takes 116 min. for an EX to fill up a 32G card. The Alexa can do it in 12 min.
    I am also waiting for my Ki Pro Mini to show up. Weren’t they supposed to start shipping at the end of October? Or was it November?
    – Don
    Don Greening
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Ron Pestes
    November 14, 2010 at 10:28 pm
    As of this morning Adorama had them in stock for $1995. Do a search as I remember seeing a couple other places that supposedly had them as well. Not sure how accurate this is though.
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
  • John Sharaf
    November 14, 2010 at 10:38 pm
    Don,
    According to latest query to AJA, there have been some “manufacturing delays” and in addition their marketing policy will have them deliver to their biggest customers first, rather than in the sequence of orders by date and time. These two factors make it very difficult to determine when deliveries will finally begin.
    JS
  • Don Greening
    November 14, 2010 at 11:48 pm
    Thanks for that, John. I was starting to wonder if such a delay was the cause. I even went so far as to read some recent AJA “tweets” but there was no mention of the Ki Pro Mini. Just an announcement that the new Kona board started shipping on Friday.
    – Don
    Don Greening
    Reeltime Videoworks
  • Don Greening
    November 15, 2010 at 2:33 am
    B&H Photo has the Ki Pro Mini and accessories available for pre-order. I don’t think anyone actually has them yet because they haven’t started shipping. If you dig further at Adorama you’ll probably find a similar situation.
    – Don
    Don Greening
    Reeltime Videoworks
  • Michael Palmer
    November 15, 2010 at 3:34 am
    I will say it is inspiring as a collective forum we are all interested in going beyond the limits of the camera manufacturers.
    Good Luck
    Michael Palmer
  • Craig Seeman
    November 15, 2010 at 3:44 am
    PMW-500 is 2/3″ CCD actually.
    It’s the first camera that allows one to format the SxS to Fat32 for EX or UDF for 50mbps 4:2:2 MXF.
    Using CCD instead of CMOS and offering MXF are a couple of key things that separate it from the PMW-350. Sony says it’s a “B” camera to the 800 (Sony likes calling things “B” cameras a lot these days). Actually I told them it could be the “A” alternative as I suspect the transfer speed for full resolution MXF from SxS is going to be faster than XDCAM Disc and that can be critical in ENG work.
    https://pro.sony.com/bbsccms/assets/files/micro/xdcamex/brochures/pmw500_V2474.pdf
