Activity › Forums › Adobe Illustrator › PDF’s from Illustrator – Problems with Trim Marks
  • PDF’s from Illustrator – Problems with Trim Marks
    Posted by Natasha Buthee on September 9, 2008 at 3:04 pm
    Hello, I hope someone can help me.
    I have always had difficulties with bleed and trim marks when saving files as pdf’s from illustrator. They never seem to be included on the pdf no matter what I do.
    Just so you know I am used to saving as pdf’s from Indesign and that always works!
    Is it something to do with my illustrator settings? Any help would be most appriciated as its doing my heeeeeed in!!
    Cheers
    Tasha
    Jeff Kelley replied 18 years ago 2 Members · 1 Reply
  • Jeff Kelley
    September 9, 2008 at 9:48 pm
    I assume your “saving to pdf”. If so, make sure you have you bleeds and mark on the the first dialog box that pops up
    http://www.willinois.com
