Activity Forums Adobe InDesign PDF to Indesign
  • PDF to Indesign
    Posted by Jeff Cochran on February 26, 2009 at 9:25 pm
    Hello all:
    I have a fun one. I need to take an old PDF and convert it to an Indesign Document, change the page size and color space before it goes to the printer.
    Any suggestions?
    Hayri Yanik replied 17 years, 5 months ago 3 Members · 2 Replies
  • Kelly Johnson
    February 28, 2009 at 2:25 am
    You can’t really convert it to a pure ID.. you can import it of course and then create a new pdf to the specs.
    I haven’t used CS4 so I’m not sure if there is a plug-in or new option but of course it would matter if the old pdf was created correctly rather than being totally rasterized or exported from Photoshop as a Photoshop PDF. You would have to be able to extract text and images.
    On the other other hand, you can just export text and images from the pdf in Acrobat and then rebuild the layout in InDesign.
  • Hayri Yanik
    April 19, 2009 at 5:48 pm
    File / Adobe Pdf Presets/using anyone.
