Activity Forums Apple Final Cut Pro Legacy PDF slides to FCP
  • PDF slides to FCP
    Posted by Jay Burgess on May 26, 2011 at 6:21 pm
    I have someone who has created a slide show in PDF format and they want to create a DVD of the PDF slideshow with voiceover. When I import the PDF file it looks fine in the viewer but when I put it in the timeline it looks blurry and crappy in the Canvas. Even rendering doesn’t clear it up.
    I saved the files as JPEGs and imported them that way but still have the same problem.
    Is there some way around this? Some way to make these slides appear clear? I’m assuming that once I burn it to DVD it will look the same as it does in the Canvas.
    By the way, I’m using Final Cut Pro 7 that comes in the latest Final Cut Studio.
    Jay Burgess replied 14 years, 11 months ago 1 Member · 1 Reply
  • Jay Burgess
    May 26, 2011 at 6:39 pm
    Never mind.
    I knew it would be something simple. The canvas was sized to fit window instead of 100% thus making it 132% which makes the text look blurry.
