Activity › Forums › Apple Final Cut Pro Legacy › PDF slides imported into FCP
  • PDF slides imported into FCP
    Posted by Greg Ball on July 18, 2013 at 7:55 pm
    We shot a series of presentations at a conference. Some presenters gave us PowerPoint slides which we’re able to convert to tiff files for editing in FCP.
    However several presentations were given to us as PDF files. Can someone advise me on how to convert those slides from PDF files to tiff files and import them into either FCP or Motion 4?
    Thanks.
    Dave Farrants replied 13 years, 2 months ago 6 Members · 14 Replies
  • 14 Replies
  • Mark Suszko
    July 18, 2013 at 9:01 pm
    I do this all the time by opening the PDF using Preview, then “save as” which gets you to a box with numerous choices such as TIF.
    This is kind of my usual tool when I want to blow up a map or office form really huge, so I can then do impressive “fly-overs” of the image in Motion, without the flickering of thin lines aliasing all over.
    There’s probably three better ways, but this is what I do and it works for me.
  • Greg Ball
    July 18, 2013 at 9:29 pm
    Thanks Mark. But there are 60 slides, and this is only allowing me to save 1 slide, even if I select all first.
    Any thoughts?
  • Mark Suszko
    July 18, 2013 at 10:54 pm
    I just tried to replicate your problem. I made a three-slide powerpoint, exported it to /pdf. Opened the PDF using Preview. Was able to export all three tiffs using the export>select tif command. I dunno, maybe our versions are not the same, but it’s working for me.
    My last trick is to use the free grab tool in the utilities folder to capture things off the screen. Sorry you have to do it 60 times. I don’t have photoshop here at home, but you might check there to open the pdf and then do a batch convert on the pages.
  • Steve Eisen
    July 19, 2013 at 1:19 am
    Get the PowerPoint Presentations from the ones that did not give them to you. It will make your workflow much easier. Make sure your slides are video safe.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Greg Ball
    July 19, 2013 at 1:34 am
    Steve, thanks but that’s not going to happen. There must be a better way to do this.
  • Dave Farrants
    July 19, 2013 at 2:44 am
    FileJuicer ($17.95) will extract all the image files from PDF’s and save in one folder as TIFFS – https://echoone.com/filejuicer/
    Web – https://www.foxvideo.co.uk
    Blog – https://foxvidpro.blogspot.co.uk/
  • Greg Leslie
    July 19, 2013 at 3:34 am
    If you have Photoshop you can open all (or selected) pages and rasterize them at a specified pixel size, then save the individual files however you want. You may need to add a background white layer, if you see transparency in the pages.
  • Mark Suszko
    July 19, 2013 at 2:12 pm
    I figured as much, since Adobe owns PDF technology, it makes sense Photoshop can manipulate it some.
  • Greg Ball
    July 19, 2013 at 2:23 pm
    Actually I tried Photoshop but it keeps crashing because of the number of slides. That’s not a good solution for me.
  • Mark Suszko
    July 19, 2013 at 2:52 pm
    Greg, what’s your hardware/software setup?
