Activity › Forums › Adobe After Effects › PDF Document and AE Question
  • PDF Document and AE Question
    Posted by James Capozzi on July 15, 2008 at 2:19 pm
    I have a situation where a client will give me a very long PDF document (like over 200 pages) and wants the information to be scrolled in a video. I have messed around with doing this in FCP and Avid but can’t seem to get it to scroll. Is it possible to create this easily in after effects? I have access to CS3.
    Right now, I go through and change each page into a TFF and create a very long page in Photoshop, invert it and bring it into Avid to scroll. It takes me nearly all day! Is there a faster answer?
    Thanks in advance.
    James Capozzi replied 18 years, 2 months ago 2 Members · 2 Replies
  • Ken Latman
    July 15, 2008 at 3:42 pm
    You can make the very long image using photoshop. I just tried with a sample PDF of 10 pages.
    1) Open your document in Photoshop. When the dialog appears as to which page you want to open, hold down the shift key and select all the images.
    2) Your pages are now all individual documents on screen right? How many pages did you open? This is important. Next go under the File Menu to Automate. Select Contact Sheet II. A dialog will appear.
    To make it easier on yourself set the units pulldown to pixels. Set the width number to the dimensions of project’s width (768, 720, 1280, 1440, etc). Check the Flatten all layers if you just want one document in the end. In the thumbnails section set the columns to 1 and the rows to the number of pages your PDF generated into documents for Photoshop. Now watch the little example on the side and adjust the number of pixels in height so you have only one document created (number of pages * comp width). You should see Page 1 of 1.
    Make sure use filename as caption is turned off. Turn off the auto spacing as well and set the vertical and horizontal to center, so all your pages tile. Set you document resolution to 72.
    3) Save document as PSD, TIFF, etc and import into After effects.
    I hope the rest is self explanitory.
  • James Capozzi
    July 15, 2008 at 4:27 pm
    Thank you so much!! It worked flawlessly!
