Activity › Forums › Adobe Encore DVD › pcm wav file changes to mpeg audio when authoring
  • pcm wav file changes to mpeg audio when authoring
    Posted by David Dicanio on May 15, 2008 at 11:13 pm
    I’m trying to author a dvd. I exported an Mpeg2 for the dvd and it has “.m2v” for the video and “.wav” for the audio. The audio properties confirm that the wav file is a pcm wav. That is what I want. But when I burn the dvd it changes the audio to Mpeg audio. Is there a setting somewhere? Is it transcoding it to that?
    I’m using Encore cs3. i’m a bit new to authoring. Thanks.
    Simon Bonner replied 18 years, 4 months ago 3 Members · 2 Replies
  • Joe Bowden
    May 15, 2008 at 11:46 pm
    Take a look at the preferences for audio encoding.
  • Simon Bonner
    May 16, 2008 at 10:07 am
    If I understand correctly, you imported a wav to your project, added it to a timeline, then built a dvd folder. You looked in the folder and found that your wav had been changed to mpeg audio.
    Wav is uncompressed and great quality, but the space on a DVD is limited and would quickly be filled up if all the audio and video wasn’t compressed. That’s why Encore has to transcode all non-mpeg file formats to mpeg upon building.
    Your best option is to output all your assets from your editing or compositing programme using lossless codecs (e.g. quicktime animation / photo jpeg) and then let Encore transcode them all for you when you’re ready to build.
    Simon Bonner
    youtube.com/simonsaysFX
