Activity › Forums › Panasonic Cameras › PCD2G and the 15″ MBP Retina
  • PCD2G and the 15″ MBP Retina
    Posted by Jim on June 12, 2012 at 1:41 pm
    I will probably upgrade laptops to the new Retina MBP 15″, but am waiting for the infrastructure to catch up. I’m using the Panasonic AJ-PCD2G to off load P2. (One USB for power, the other for data) — I am assuming that I can use the 1 USB 3 of the new MBP 15″ w/ a powered HUB to make that work?
    Any thoughts suggestions would be welcome.
    Cheers,
    Wolf Austad replied 14 years, 3 months ago 5 Members · 4 Replies
  • Shane Ross
    June 12, 2012 at 8:23 pm
    I guess we have to wait until they arrive. 2-3 weeks if you order today.
    Shane
    Little Frog Post
  • Steve Eisen
    June 12, 2012 at 11:07 pm
    You should be able to use both USB 3 ports on the new MBP. Definitely test it before you buy.
    It looks like only the 2.6 GHz has the option to upgrade the flash memory from 512GB to 768GB (Jim asked me earlier today) and Processor from 2.6 to 2.7.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Arthur Aldrich
    June 15, 2012 at 2:41 am
    To benefit from the USB 3 on the new MPB, you may want to consider the pcd30.
    https://www.panasonic.com/business/provideo/aj-pcd30pj.asp
    Art Aldrich
    OTEK TV
    Leader, NJFCPUG
    http://www.njfcpug.org
    http://www.P2Pro.com
  • Wolf Austad
    June 15, 2012 at 5:52 pm
    Yes, PCD2 can be powered from a USB HUB or even an iPhone charger.
    I have been told that the USB 3 bus you connect this to will revert that entire USB 3 bus to USB 2 speed, since the PCD2 is a USB 2 device. I don’t know if those two USB 3 connectors on your computer are on separate USB 3 busses or on the same USB bus.
    Aasulv Wolf Austad, fnf
    Director of Photography
    Los Angeles based
